Hey! I have a Unity and a DieBieMS. They both have antispark eswitches. I’ve read the advice to simply short the Unity eswitch and just rely on the DieBieMS power button. My problem is that the stock DBMS button is HUGE and doesn’t reasonably allow me to fit it inside my enclosure in a position favourable to me.
Ideally, the Unity’s switch is perfect for my space and aesthetic goals.
Question! Has anyone had success or know if third party buttons can work with the DBMS? Are there features I specifically need to seek in an alternative button? Is this a stupid question?
Any help is greatly appreciated as I’m currently considering bypassing the DBMS discharge until I figure this out, which is stupid.
I don’t use the one one that is supplied with the DieBieMS either, way to big. You can use almost any pushbutton as long as it’s momentary and not latching. You don’t need one with led if you don’t want that feature. Most pushbuttons have both NC/NO (normally open/closed), you will need it to close when pressed.
Thanks for the replies guys! I’ve been tearing my hair out over this. @M77 Thanks for the explanation!
@janpom Any chance you can help me out with what wires go where? I’m aware the yellow wire on the DBMS harness isn’t used on the standard button, so I assume it’s much the same with this, too.
