I would like to buy some mounts for a used mountain board as my budget is a little tight. I would like some 6384s also… nothing needs to be too pretty.
Would consider 6374s fit the deal were right.
I do have a spare set of these… any chance those would fit with just the matrix2 adapters (instead of the cal2).
I just measured and one is 36mm and one is 43mm (bolthole centerline diameter) so no. But if you message Boardnamics they are very helpful, they may have something.
The spacing information is very helpful. I messaged him. It doesn’t hurt to ask.
He responded and confirmed that he doesn’t have a way to make these things fit on Matrix2. I’ll give the used option a couple more days and then I’ll just suck it up and order the Boardnamics ones.
if the Boardnamics ones are in stock I would suggest you scoop them asap…
not always around . no better deal.
