Recently got a unity from bobby and a set of new 6374 190kv tb motors. Running 12s and 3d servisas mini urethane gear drives 2.4 ratio on tb110’s. My question is how many motor amps could I push on this set up? I came from 170kv maytechs pushing 75amps and the new setup feels super sluggish. Its fast as fuck but torque is severely lacking compared to 170kv. I have zero experience with unities and 190kv motors which is why I’m asking here. My current motor amps are at 75, can I get away with 80 maybe even 90? I’ve replaced the unity motor leads with 10awg and 5.5mm bullets. My area is mostly flat but I ride in traffic, I needed more top speed so I didnt impede traffic thus my choice of moving to 190kv. 170kv was more torque than I could handle but the 190s are not even close. Thanks for help in advanced.
Run them at 90 like the sites specs state.
Your torque will return. Your unity will be fine also.
Can’t believe I missed that. For some reason I though specs stated 65amps, lol. Thanks for the help!
The motor kv difference is small but will be noticeable as well. Torque down a bit, speed up a bit.
Technically, as much as u want before it starts to saturate and heats up too fast. Start from 90, bump it up bit by bit until no performance gain, then back down a bit
