I have some weird tools that I frequently used that are not common in an esk8 toolbox. I thought I’d share some and get you folks to do the same.
Here’s the 1st item…
This thing is awesome, will fill a tire in 1.5 seconds.
Those things are awesome!! I have one similar strapped to my mountain bike for trail fixes!!
You wouldn’t be able to use that on a 5x2 rightttt??
I just used it on a 6x2 6 shooter as a test. You definitely don’t wanna hold the trigger too long.
Just switched to pneumatics recently how concerned should I be about popping a tire (on kit from torqueboards)? Does everyone just carry a spare or slime/refill kit?
Can’t say I use anything non standard tools wise really, Dremel, drill, 3d printer, tape, epoxy, paint all the regular stuff.
I normally use this…
Hemostats and a pinball. Can’t tell you how many times those are exactly what I needed…
I’m gonna need to you to show your work on that
Yah hemostat I could understand not sure what you mean by pinball though?
I popped a tire on my first pneumatic rides, after that slimed them and never had another flat, so I would say its a must
Is there a downside to sliming?
Less squish in the tire? Less balanced roll?
I didn’t feel anything, I though that it would vibrate in slow speeds until the slime was spread out, but nothing happened
only downside, except for overfilling and an out of balance sludge rolling in your tires is, no inner-tube patch will ever stick… evAr!
When you need to hold a round hole while you hammer stuff, it’s always the right size
Surrrreeee “Solvents”
There was one time where i had a dangerous solvent and a drink beside each other.
Guess which one i took a sip from when working on stuff
I can’t imagine drinking anything that ranks near MEK or other solvents
I couldn’t even stand near the table where we were using them on a school project
How did you clean your mouth out lol? Mouthwash back to back to back?
Pretty much, then downed a couple pepto bismol and quickly skated to the nearest clinic.
I drank white spirits by accident and nearly died
Better luck next time
