Ultralight Board | Single Drive | Drill batteries | Airline Friendly
I want to start brainstorming my next build focused on travel. This build has to be CHEAP and flight safe.
Parts I’m thinking about:
Deck: Skateshred mini with kicktail $22
Trucks: Caliber 2. $40
Wheels: A set of Orangatangs I already have on hand. Free
Motor: Single 6355 190kv TB or something used. $90
Mount: Boardnamics CB2 mounts without idlers. Free
ESC: Either something I have on hand or the new MakerX. $90
Remote: I will either stick a Hoyt receiver for the puck I already have in there or use a spare nano I have laying around. Free
Battery: 2x of these in series to create a 40v 3ah pack (60wh each). This would be a total of 120wh. I don’t foresee any issues at the airport with powertool batteries but if you do please speak up below. $90
Pulleys: 12T/36T that I have on hand. Free
Enclosure: Something I design and 3d print, will probably be the last part I source/create. Free
Odds and ends:
This adapter is all I could find online for the batteries. If you have any better ideas I am open to them. 2x $20 = $40
Wires and other bits: ~$20
GRAND TOTAL: ~$400
could be less depending on how many spare parts I can find
What am I missing?
The deck might be a little long for portable travel.
I know my tayto is 31 inch and even thats a little big
May I suggest a skate shred mini deck?
https://www.skateshred.com/wholesale-blank-longboard-decks/blank-mini-skateboard-cruiser-decks.html
Good call. What are your thoughts on this one?
Looks good, kicktail also looks very usable.
To keep the width down use 9" Caliber 2
https://www.amazon.com/dp/B00QNOZWBY/ref=cm_sw_r_cp_apa_i_FmJcEbTBF857W
My bad, I meant to use the 9" version. Good call thanks
I think I have a old TB 6355 with a broken magnet if you wanna try and fix it.
Thanks! I’ll take a look at what I have laying around and get back to you. I may have one with the same problem lmao
