canbus cable between the two of them
you donât want dual trampa esc operating independently, better to have them paired and good idea to also enable traction support.
I personally wouldnât suggest that without knowing details of the build. Itâs not always a good idea to enable traction control.
He said trampa, so I was replying to that specific esc, but point taken.
Why would traction control be bad, what are some of the problems youâve come across?
Dr. e skateboard fell down because he didnât have traction control enabled when he went over gravel on the road, hit his head, blacked-out woke up in the hospital with a broken collar bone and bruises on his face. He believes having traction control might have prevented that.
Mentions it at 6:18 in the video.
It doesnât matter if itâs a trampa vesc or any other vesc based esc, traction control does work the same.
Traction control does work as well during braking. If during braking one wheel will lose contact to the ground and get stopped, all wheels will stop or lets say the braking force will be stronger then you would expect. That can make you crash as well, especially if you run a quad with traction control enabled.
This is good to know, Iâll be more alert with my stopping since I got traction control on. On a quad is it possible to disable the front motors from acting as breaking?
Yes; set the âmotor minâ or âMotor Current Max Brakeâ to zero amperes on each of those motors.
