I ended up with super lube, not the greatest choice but I have it.
Whats the cause for my battery meter reading ~97% full at 48.5v for a 12s. Is this a battery curve setting or is the used battery I bought sketch
Is what chatgpt recommended i use for the bearings i put back together after i exploded them. It said it wouldnt interact with the grease on the gears.. Also it will be a while before i grease the gears so the lube should be somewhat dry by that point
