The Hardware Exchange (Serious)
A place to inquire for and offer up all the bits that are too valuable to hand out for free yet too small to make a thread about!
You can either list out things you are looking for or things that you have (or will have) extras of, a great source for high end hardware is McMaster-Carr but it’s expensive and you need to buy a lot so it sucks when you only need 5 screws and have to buy 100 so maybe this helps.
For formatting, before each item have (needed / ordering / owned) with a + to signify ‘or more’ and a - to signify ‘or less’
Example
  • (10+ / 50 / 0) Black-Oxide Alloy Steel Socket Head Screw M4 x 0.7 mm Thread, 35 mm Long
I have brand new Carbon GT deck lid bolts.
M4 x 12 hex socket countersunk 10.9 part # FHS100412-100M1
Sold in packs of 100 only
I have an order for the following ready so let me know if you already have spares of or will also want some
  • (10+ / 25 / 0) Black-Oxide Alloy Steel Socket Head Screw M4 x 0.7 mm Thread, 60 mm Long
  • (6+ / 50 / 0) Black-Oxide Alloy Steel Socket Head Screw M5 x 0.8 mm Thread, 25 mm Long
  • (6+ / 50 / 0) Black-Oxide Alloy Steel Socket Head Screw M5 x 0.8 mm Thread, 35 mm Long
  • (40+ / 100 / 0) Button Head Hex Drive Screw Black-Oxide Alloy Steel, M5 x 0.80 mm Thread, 30 mm Long
  • (20+ / 20 / 0) Button Head Hex Drive Screw Black-Oxide Alloy Steel, M5 x 0.80 mm Thread, 50 mm Long
  • (8+ / 100 / 0) Zinc-Plated Steel Washer for M10 Screw Size, 10.5 mm ID, 20 mm OD
For small qty and cheaper (slower) shipping than McMaster-Carr, I’ve used https://www.boltdepot.com to good results. $4.95 economy shipping to US destinations.
