what is your general opinion on suspension, like avenue trucks have ?
if its worth i would like to try design a riser on the same principle, i found a basic representation in the old forum back from '17 that i would like to adapt
could add regular or flat springs between the plates or experiment with some materials for damping…
if a more flexy deck or pneumatic tires is no option, could this give a reasonably smoother ride on urethane wheels, given the construction is stiff enough for higher speeds ?
wobbles. its almost inevitable. If you can manage to find the balance between the stiffness of the suspension to risk of wobbles at speed, i think this idea might be able to work if executed properly.
I don’t know what leaving the bushings out means BUT angles definitely affect the stability and ride of the board. The Evo is a notorious example of this as it incorporates +15/-15 degrees on both front and rear to make it stable as fuck.
sorry this was probably worded poorly, i ment that even if i use the softest bushings and barely crank them down, my evo is really hard to get wobbles on (because of the angles as you stated)
so its hard for me to imagine with a suspension like this it would be prone to wobbling, thats why i was hoping for more feedback on the idea
edit: looks like i will get some of these done in a local metal-workshop, ill report back on the results
Suspension like this almost has to introduce an element of slop/wobble. Your angles are keeping you from experiencing it now, but I believe you’ll have some side-to-side caving to deal with.
However, I leave the house with my underwear on the outside frequently, so I could be wrong.
And here’s a link to my Google album
Where I documented the making of my custom hanger in order to mount hub motors to avenue rkp suspension baseplates.
The complete setup in the video has now transformed to a much more compact Carver.
I love the way it rides! It is super nimble and the avenue suspension is STRONG. It does not exhibit any wobble. The proper bushing setup is necessary to achieve this control… I love this nimble carver with great asphalt vibration reduction.
i have tried various soft risers… the problem is there is just like zero travel on impact, the rubber just doesnt allow enough compression to have an effect on bigger hits
