Surf Rodz RKP 176mm 10mm axle
Guys. I am looking for a SR 176mm, better black or red. I need only the hanger so no problem if you don’t have the base plate. Its OK also borrow it if someone has it but doesn’t want to sell it. I need to see if I can short a bit the drive I am making with the SR 200mm. Way too wide :sweat_smile:
150mm SR doesn’t fit dual motors unfortunately. Thanks a lot.
I am in EU btw
Just as warning, it seems that mounts made for surfrodz rkps only fits 200mm, not 176mm
Depends on the mounts
yeh that’s no problem I make my own drives, my only concern is the width.
Bump bump bump :grin:
https://www.ebay.co.uk/p/2112806495?iid=112775269335&chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=112775269335&targetid=878026981600&device=c&mktype=pla&googleloc=1007030&poi=&campaignid=9437609954&mkgroupid=94749635494&rlsatarget=pla-878026981600&abcId=1139126&merchantid=114941942&gclid=CjwKCAiAhc7yBRAdEiwAplGxX6lx4NT5ScDO39mz-rSXL_fqFe-eTnqEQ6IpkBUuwVELBvk05Oj8cxoCFggQAvD_BwE
Have seen it. But then it’s cheaper on sickboards. Single is 79 Euro. And I need one at most. I don’t know I should try it first. Maybe I can just print it to see if it will work.
I have a 176mm 10mm hanger with a broken bolt down in the bottom of the hole, then it got a threaded insert on top of that. Still takes the same diameter shoulder bolt but needs to be shorter on that side. will this work for you?
Thanks for the offer but I need to use a long shoulder bolts and I will be afraid that it doesn’t have enough support. That’s a pity
