It seems like the Stormcore has a built in Bluetooth module but I can’t seem to connect to it. The control mode is set to PPM and UART and everything works based on my RC car remote. What could be the problem? The baud rate(it’s currently the default 115200)? Or some other settings?
Yeah I have to check my second hand 60d because I tried to set it up and it wasn’t coming up
But I didn’t really try hard I just went on the Stormcore app and it wasn’t coming up either
Contact lacroix. My 60d+ had the bt module missing. They can walk you thru some testing stuff if your comfortable with it. Or they’ll ask you to straight up mail it back.
I’ll get you the right stuff on Monday, just write to us. Worst case is we will do a swap out for a working unit. Just wait until then, the process goes by pretty quick. Also we might have a slight delay in some supporting, I’ve got a busy coming week.
Silly suggestion, If you have more then one vesc ap, try discovering with the others. I had a vesc that would be discovered with Yours Truly but not the vesc app or the FreeSK8 app. As soon as I opens and closed Yours Truely, the other apps would be able to discover the vesc.
