Spur talk ⚙️ SRO
Who can say? The mind of a motor manufacturer is unknowable.
But if I had to guess, Id say it’s some combination of:
  • it’s technically weaker. Weak enough to be a problem for our applications? Who knows. But technically weaker.
  • it costs more. It’s two operations instead of one, and you have to make sure that the two features are clocked 180° from each other, which takes extra care on a part which otherwise has no concern for how the various features are clocked. Not a big deal for experienced machinists, but slightly harder than not doing it.
  • not all d-shaft axles/gears/pulleys are the same. So if the goal of the b-shaft is to be universal, it’s gonna fail at that.
None of those are particularly strong reasons, but people don’t generally need strong reasons to NOT do something lol
So why 8mm shaft as oppose to 10mm?
So far it seems like an 8 mm diameter with a flat spot 1mm deep is the most common standard I find
