Has anyone come across an issue where when you plug in a 12S battery it reads the voltage as a 4S (16.6v it was reading ) battery? 10S seems read fine and the ESC works fine. This is only just happened after 1 to 2 years of running a Unity on 12S with 130kv motors.
I still need to pull it all apart and see if theres anything obviously blown on the Unity.
I have an adapter that allows me to run either 2 or 3 LiPos (1x 6S LiPo & 1x 4S LiPo or 3x 4S LiPo usually) and I had plugged it in wrong; giving me some weird 4S voltage output. As I was out in the field and the time I didn’t have my multimeter so hadn’t checked the final voltage output and I was just using the FOCBOX UI app.
Lesson learnt; label the plugs better and don’t be a numpty!
For anyone else stumbling on this thread in the future, I have noticed more than once that if a previously working ESC suddenly starts reading a few volts too low on the battery voltage, it could be just about to blow a DRV. Don’t go too far from home.
