So i was thinking, if you were to punch a hole in a piece of nickel strip, could you put an XT60 leg through that and make a solid solder connection?
Basically this is for the Modular battery pack idea, as I need a low-profile way to connect the female XT60’s to the battery back that can handle the high amperage that the battery puts out.
I looked at PCB already, but not only is it slightly thicc, but its not capable of the amperage needed.
Thoughts guys?
