Hi
Just finishing my build not happy with the width of my trucks looking for slightly narrower trucks than tb
Any recommendations? Or any for sale
Thanks
For what motor setup?
Boardnamics 184
Bear 120mm
Caliber 180
Boardnamics 184
Paris v2 195
Don’t try to put motor mounts on round truck hangers. It’s a bad idea.
If you’re going to weld them on, then that’s another story.
6374 x2
Those won’t fit side-by-side on anything much smaller than 218mm.
Unless you want one motor in front of the truck and one behind the truck — or one motor on the back truck and one motor on the front truck (dual diagonal, rear heelside + front toeside) — then you can probably use 184mm hangers.
I’m surprised we don’t see more of this. it would be relatively easy to weld to a billet truck like the BN184
STAY
And that’s why I asked.
Caliber E trucks suck. They bend and are just generally inferior in every way to the @Boardnamics 184mm option, which is nearly functionally identical, except at ten times the quality level.
99% of longboard trucks are smaller than 218mm
So that would be a no, then?
I would not attach motors to round truck hangers unless I welded the mounts on the hanger.
When in doubt, use weld sauce on everything
When in doubt, just don’t use hangers that are round, like Paris for example.
Nothing against those trucks on analog longboards or for front trucks, but they aren’t good for mounting motors to.
Dickyho mounts work suprisingly nice!
