The bottom enclosure could b fine for a flex deck, but the top one could never work on a flex deck, it’s just too long
Will the batter you break if I use a those enclosures on it
That is what I have been asking the whole time
You could make some cut on the enclosure to allow it to flex, but waterproofing will be hard
Waterproofing is necessity in london
Well… the guy that built your battery said
So you need to mount your battery in a way the flex is minimal. = you don’t have a flex pack
Your enclosures are not flexible and to big to be mounted far enough away from the center.
No idea what you’re saying.
Will the battery break if I use those enclosures
It was answered later on
I guess I will use the drop down stiff deck then
The problem is when you ask questions you don’t give us near enough details and just expect us to know what parts you have…
Are you going to have enough clearance with how tall those enclosures are on a drop down deck
Sorry just really desperate to get his build running and now I realise I didn’t calculated enclosure length properly
Got 97mm and I can use some risers
Do you know if the meepo v2 deck has large flex when I tried it
The board didn’t flex much
Honestly no idea.
I totally understand.
But what your learning right now is if you don’t take the time to research all your parts and compatibility you’re going to run into problems like this over and over again.
I know
From day 1 the amount of lessons I have learnt about how not to rush into things and to think about them properly
I did the same thing dude, the first $600 I spent on esk8 pretty much went down the drain.
Did you try to rotate smaller enclosure for 90 degrees? Is it too wide for your deck?
Are you sure your deck is really flexible? Some flex is normal for almost every deck
Best way to test is to put trucks on it and stand in the middle.
So the deck I am currently using has quite a bit of flex I will experiment some more with the meepo one which I don’t think has to much
What about 2 bricks on either side
That could work i guess
