Show me your top mount Enclosure [Wiki]
Simple rules:
  1. Post photos of your top mount battery and its housing.
  2. Post your configuration, cell type (ex. 18S20P Samsung 40T cells) and who made it.
  3. Link to enclosure used.
@Andy87 @taz @Lee_Wright @anorak234 @mikenyc @rich @Riako @J0ker @ixf @davidc @Mobutusan @370HSSV @rafaelinmissouri @Jhicks95 @Xclr8r @Saturn_Corp @janpom @Martin @Santino
@sleepless :
Edit: use a case database search to find something that fits:
Here’s a list of enclosure brands and dimensions that may be a useful addition to this thread, as of October 2021:
(I was searching for a good medium size aka 12s5p in NESE modules or ~12s8p welded pack. Most of these brands offer smaller and larger versions)
BRAND MODEL INTERIOR EXTERIOR WEIGHT EMPTY LINK PRICE
Seahorse SE56 8.4 x 4.4 x 2.3 in 9.5 x 5.8 x 2.8 in 1.31 lb https://seahorse.net/shop/micro-waterproof-cases/56-micro-case/se56/ $14.53
Seahorse SE130 7.5 x 5.0 x 3.3 in 8.8 x 7.4 x 4.1 in 1.41 lb https://seahorse.net/shop/protective-cases/130-protective-case/
Seahorse SE230 10.6 x 6.1 x 3.9in (27 x 15 x 10 cm) 11.9 x 8.5 x 4.8in (30 x 22 x 12 cm) 2.15 lbs (.98 kg) Seahorse SE230 - Waterproof Protective Hard Case $24.52
Seahorse SE300 9.2 x 7.1 x 4.1in (24.13 x 18.67 x 10.41cm) 10.7 x 9.8 x 4.9in (27.43 x 25.02 x 12.37cm) 2.45 lbs. (1.12kg) Seahorse-SE-300-Small-Hard-Protective-Waterproof-Shipping-Cases-Containers-Boxes $27.21
Pelican Ruck R20 (ideal for ESC only) 7.07 x 3.39 x 1.95 in (18 x 8.6 x 5 cm) 8.96 x 4.83 x 2.88 in (22.8 x 12.3 x 7.3 cm) 1.26 lbs (0.6 kg) R20 Personal Utility Ruck Case | Pelican Official Store $44.95
Pelican Ruck R40 (ideal for ESC only) 7.63 x 4.70 x 1.90 in (19.4 x 11.9 x 4.8 cm) 9.84 x 6.12 x 2.89 in (25 x 15.5 x 7.3 cm) 1.68 lbs (0.8 kg) R40 Personal Utility Ruck Case | Pelican Official Store $54.95
Pelican Ruck R60 8.90 x 5.37 x 2.96 in (22.6 x 13.6 x 7.5 cm) 11.14 x 6.86 x 3.88 in (28.3 x 17.4 x 9.9 cm) 2.34 lbs (1.1 kg) R60 Personal Utility Ruck Case | Pelican Official Store $64.95
Pelican 1150 8.29 x 5.79 x 3.75 in (21.1 x 14.7 x 9.5 cm) 9.44 x 7.80 x 4.29 in (24 x 19.8 x 10.9 cm) 1.61 lbs (0.7 kg) 1150 Protector Case | Pelican Official Store $39.95
Pelican 1200 9.31 x 7.13 x 4.12 in
(23.6 x 18.1 x 10.5 cm)
10.67 x 9.75 x 4.86 in
(27.1 x 24.8 x 12.3 cm)
2.87 lbs (1.3 kg) 1200 Protector Case | Pelican Official Store $54.95
Pelican 1300 9.17 x 7.00 x 6.12 in
(23.3 x 17.8 x 15.5 cm)
10.62 x 9.68 x 6.87 in
(27 x 24.6 x 17.4 cm)
3.09 lbs (1.4 kg) 1300 Protector Case | Pelican Official Store $64.95
Pelican iM2050 9.50 x 7.50 x 4.25 in (24.1 x 19.1 x 10.8 cm) 11.80 x 9.80 x 4.70 in (30 x 24.9 x 11.9 cm) 2.70 lbs (1.2 kg) iM2050 Storm Case | Pelican Official Store $54.95
Pelican Vault V100C 11.00 x 8.00 x 4.50 in (27.9 x 20.3 x 11.4 cm) 12.28 x 12.03 x 5.16 in (31.2 x 30.6 x 13.1 cm) 3.15 lbs (1.4 kg) V100C Vault Equipment Case | Pelican Official Store
Evergreen 120 7.6" x 5.18" x 3.2" 8.7" x 7.5" x 3.9" 1.55lbs https://www.amazon.com/Evergreen-Compact-Camera-Protective-Pluck/dp/B097J1GL42?ref_=ast_sto_dp&th=1 $25.95
Evergreen 230 10.6" x 6.1" 4.0" 11.9" x 8.6" x 4.8" 1.51lbs https://www.amazon.com/Evergreen-230-Storage-Capacity-Protective/dp/B0983Z4HYZ?ref_=ast_sto_dp $34.95
Evergreen 300 9.5" x 7.4" x 4.1" 10.8" x 9.9" x 4.9" 2.65lbs https://www.amazon.com/Evergreen-300-Magazine-Capacity-Protective/dp/B098R3MQK3?ref_=ast_sto_dp&th=1&psc=1 $34.95
Monoprice 6.6L 10620 9.57in x 7.17in x 6.18in (243 x 182 x 157 mm) 10.63in x 9.09in x 7.28in (270 x 231 x 185 mm) 3.1 lbs (1.4 kg) Pure Outdoor by Monoprice Weatherproof Hard Case with Customizable Foam, 10 x 9 x 7 in - Monoprice.com $20.99
Monoprice 7.0L 12681 11.0in x 7.9in x 4.8in (280 x 200 x 122 mm) 12.0in x 10.6in x 5.7in (306 x 269 x 145 mm 4.39 lbs (1.99 kg) Pure Outdoor by Monoprice Weatherproof Hard Case with Customizable Foam, Fits HUBSAN Quadcopter Drones, 11 x 8 x 5 in Internal Dimensions - Monoprice.com $39.99
Monoprice 3.0L 12680 8.8in x 6.4in x 3.8in (224 x 162 x 96 mm 9.7in x 8.5in x 4.5in (246 x 216 x 115 mm 2.49 lbs (1.13 kg) Pure Outdoor by Monoprice Weatherproof Hard Case with Customizable Foam, 10 x 8 x 4 in - Monoprice.com $29.99
Nanuk 905 9.4 × 7.4 × 5.5in
239 x 188 x 140 mm
12.5× 10.1 × 6.0in
318 x 257 x 152 mm
3.3 lb (1.5 kg) NANUK 905 | Official NANUK Protective Case Online Store & Indestructible Hard Case – NANUK USA $49.95
Gator Titan GU-0907-05 9.4″ x 7.4″ x 5.5″ 12.5" x 10.1" x 6" 3.3lbs https://www.gatorcases.com/products/utility/waterproof-cases-empty/titan-utility-waterproof-cases-empty/utility-case-9-4-x-7-4-x-5-5-gu-0907-05-wpnf/# $80
Eylar 10.62 9.17in x 7in x 6.12in 10.62in x 9.68in x 6.87in 10.62" Small Deep Gear, Equipment, Camera Hard Case, Waterproof, Dustproof, Shockproof with Foam - External: 10.62" x 9.68" x 6.87" Internal : 9.17" x 7" x 6.12" $39.99
Eylar 10.62 B 9.25in x 7.12in x 4.12in 10.62in x 9.68in x 4.87in 10.62" Small Gear, Equipment, Camera Hard Case, Waterproof, Dustproof, Shockproof with Foam - External: 10.62" x 9.68" x 4.87" Internal : 9.25" x 7.12" x 4.12" $34.99
MEIJIA B07RZGFSCY 9.25inX7.12inX4.12in 10.62inX9.68inX4.87 https://www.amazon.com/Portable-Weather-Waterproof-Equipments-x9-68x4-87inches/dp/B07RZGFSCY $32.99
MEIJIA B07SL3CS3Y 9.17x7x6.12inches 10.62 x9.68x6.87inches https://www.amazon.com/dp/B07SL3CS3Y/ref=emc_b_5_t $39.99
Amazon Basics Small Case 10.9in x 7.9in x 4.7in 12.1in x 10.6in x 5.9in https://www.amazon.com/AmazonBasics-Hard-Camera-Case-Small/dp/B01L0LVDJO?th=1 $44.99
Condition 1 184 9.29in x 7.23in x 4.13in 10.63in x 9.63in x 4.73in 3.1 lbs 11" Small Storage Case #184 $45.99
Smatree Smacase GA700-2 9 13/16in x 7 3/8in foam 11.02 X 9.68 X 6.14in https://www.amazon.com/gp/product/B00KA4PVDC $71.99
Underwater Kinetics 206 5.5 x 3.5 x 2.0 in / 14.0 x 8.9 x 5.1 cm 6.7 x 4.7 x 2.3 in / 17.0 x 11.9 x 5.8 cm 0.4 lbs / 0.2 kg 206 UltraBox – UWK Case $16.95
Underwater Kinetics 308 7.9 x 4.7 x 2.6 in / 20.1 x 11.9 x 6.6 cm 9.1 x 5.9 x 2.9 in / 23.1 x 15.0 x 7.4 cm 0.7 lbs / 0.3 kg 308 UltraBox – UWK Case $30.30
Underwater Kinetics 312 11.5 x 8.9 x 3.1 in / 29.2 x 22.6 x 7.9 cm 12.2 x 10.4 x 3.3 in / 31.0 x 26.4 x 8.4 cm 1.9 lbs / 0.9 kg 312 UltraBox – UWK Case $83.30
Underwater Kinetics 409 8.5 x 6.0 x 5.7 in / 21.6 x 15.2 x 14.5 cm 9.4 x 7.2 x 6.2 in / 23.9 x 18.3 x 15.7 cm 1.6 lbs / 0.7 kg 409 DryBox – UWK Case $56.10
Underwater Kinetics 609 8.50in x 6.00in x 5.70in (21.59 x 15.24 x 14.48 cm) 9.40in x 7.20in x 6.20in (23.88 x 18.29 x 15.75 cm) 1.70 lbs (0.77 kg) UK 609 DryBox Equipment Case | 8.5 x 6 x 5.7 $47.90
Andbao PP-2411 9.45 x 7.48 x 4.17in 11.97 x 9.76 x 4.72in 1.4 kg PP Alloy Protective Case - PP-2411(304*248*120mm) - Ningbo Andbao Enclosure Co.,Ltd.
Andbao SZ-2614 260200143mm 280246156mm 1.2 kg https://www.andbao-case.com/products/sz-2614-ID593.html
S3 Cases T5000 9.37in x 7.34in x 4.08in (238 x 186.4 x 103.6mm) 10.18in x 8.55in x 4.78in (258.6 x 217.2 x 121.4 mm) 2.80 lbs (1.3 kg) https://www.leisurepro.com/p-s3t50/s3-t5000-watertight-case-with-foam?origterm=t5000&searchredirect=true $47.95
S3 Cases T5500 9.37in x 7.34in x 6.08in (23.8 cm x 18.6 cm x 15.44 cm) 10.18in x 8.55in x 6.78in (25.86 cm x 21.7 cm x 17.22 cm) 3.58 lbs. (1.62 kg) https://www.leisurepro.com/p-s3t55/s3-t5500-watertight-case-with-foam?origterm=t5500&searchredirect=true $42.95
B&W International Type 1000 250 x 175 x 95 mm / 9.8 x 6.9 x 3.7 inch 270 x 215 x 105 mm / 10.6 x 8.5 x 4.1 inch 0.7 Kg / 1,54 Ib https://www.amazon.com/Type-1000-Outdoor-SI-Black/dp/B00H24Y5JO?th=1 $35.95
B&W International Type 2000 250 x 175 x 155 mm/ 9.8 x 6.9 x 6.1 inch 270 x 215 x 165 mm / 10.6 x 8.5 x 6.5 inch 900 grams / 1.98 lbs B&W Type 2000 Outdoor Empty Case | Wayfair $49.97
Explorer 2214 8 11/16 in x 6 5/16 in x
5 11/16 in
9 11/16 in x 8 7/16 in x 6 3/8 in 2.56 lbs copolymer polypropylene waterproof case - Explorer Cases 37.64
Explorer 2712 0.9inL x 7.9inW x 4.7inD 12in x 10 5/8in x 5 11/16in 3.57 lbs https://www.amazon.com/Explorer-Cases-2712-EXPLORER-Electronic/dp/B000JLO4FW $50.60
SKB iSeries 0907-4 9.50 in (24.13 cm) x 7.38 in (18.75 cm) x 4.13 in (10.49 cm) 10.73 in x 9.69 in x 4.80 in 2.57 lbs http://www.skbcases.com/industrial/products/prod-detail.php?id=437 $47.00
SKB iSeries 0705-3 7.50 in (19.05 cm) x 5.00 in (12.70 cm) x 3.25 in (8.26 cm) 8.36 in x 6.70 in x 3.83 in 1.22 lb https://www.skbcases.com/music/products/proddetail.php?f=&id=840&o=&c=153&s=75 $37.99
Apache 2800 11-7/8 in. x 9 in. x 5-5/16 in. 13-1/2 in. x 11-3/8 in. x 6 in. https://www.harborfreight.com/2800-weatherproof-protective-case-medium-black-63926.html $27.99
Apache 1800 8-1/8 in. x 5-5/8 in. x 3-3/4 in. 9-1/4 in. x 7-1/2 in. x 4-3/8 in. https://www.harborfreight.com/1800-weatherproof-protective-case-small-64550.html $12.99
Trampa Classic Monster Box MkV 251x193x81mm 271x210.5x87mm 1266g (2.8lbs) Classic MONSTER Box - NO VESC MOUNTING Panel £200 ($278.94)
Trampa Massive Monster Box 274x207x83mm 290x228x91mm 1452g (3.2lbs) 2WD MASSIVE MONSTER Box with NO VESC Mounting Panel £200 ($278.94)
Polycase WP-35 j-box 0.193in wall thickness 10.43 x 7.28 x 3.74 in / 264.92 x 184.91 x 95.00 mm 1.70 lbs WP-35 Polycarbonate Electronic Enclosure with NEMA Rating $43.39
LeMotech black/grey, screw down j-box. multiple sizes 10 x 6.9 x 3.4 inch (255 x 175 x 87 mm) 10.4 x 7.2 x 3.7 inch (263 x 182 x 95 mm) https://smile.amazon.com/LeMotech-Plastic-Electrical-Project-Junction/dp/B0895K3T8S?ref_=ast_sto_dp&th=1 $22.59
QILIPSU Hinged j-box,multiple sizes 198 x 148 x 104mm (7.8 x 5.83 x 4.09 in) 220 x 170 x 110mm/8.6" x 6.7" x 4.3 https://smile.amazon.com/QILIPSU-Stainless-300x200x170mm-Waterproof-Electrical/dp/B085QCT543/ref=sr_1_5?_encoding=UTF8&c=ts&dchild=1&keywords=Electrical%2BBoxes&qid=1634839098&qsid=141-7471007-6831615&s=lamps-light&sr=1-5&sres=B00274SLK8%2CB00H8NV1SM%2CB075DHRJHZ%2CB096X82P1L%2CB00527IQ70%2CB005UPANU2%2CB07TYNYW1S%2CB08TR2C42F%2CB08ZSWNRCH%2CB07ZBPJ9QL%2CB08282SQPT%2CB08KY7VK8W%2CB077QM9VM9%2CB07KW2JBJ3%2CB08N6W6LCK%2CB07RT6NWTR%2CB07MHFZHDT%2CB07PVVDNSW%2CB089JBKRW2%2CB07RVN91WB&srpt=ELECTRICAL_HOUSING&ts_id=495308&th=1 $26.99
FIBOX junction boxes, too many to list - - - Plastic Electrical Enclosures | Waterproof & Non Metallic | Fibox USA -
Photo, bc ̶i̶t̶’̶s̶ ̶r̶e̶q̶u̶i̶r̶e̶d̶ @Venom121212 beats me with a sack of oranges
Harbor Freight Apache / Pelican style - more robust but you lose space to all the exterior latches and hinges
Seahorse 300 - popular alternative, most cases come in colors other than black
Polycase WP-35 junction box style - thinner walls, lighter weight, screw down style requires tools to open
LeMotech ABS waterproof jbox, hinged
Underwater Kinetics hybrid style
enclosure top mount emtb topmount top-mount pelican nanuk seahorse apache electronics enclosure uk underwater kinetics drybox dry box hard shell waterproof airtight watertight ip65 carrying case
10s5p Samsung 30q cells
Made by @hyperIon1
12s4p 30q and hot swappable 2x 6s 10Ah lipos in series.
12S6P 30q
Pelican 1150.
10s4p 40t.
12S7P Samsung 30Q made by yours truly
2x Trampa Vesc6
2x HK SK8 149kV
e-toxx mini gear drive 5:1
concave pads mod
MBS F5 bindings
Build log (sort of) Trampa 12s7p, VESC6, 6374 sk8, e-toxx mini gear drive
Forgot to add this:
Battery: 12s8p Samsung 30q
Made by: me
Case:
10S1P 20AH lithium polymer battery.
I’m using fomex.
This was my setup until 2 months ago.
Work In Progress - Custom enclosure for 12S8p 18650
WIP - up to 13s5p 18650 with space for dual ESC’s with or without charge port, voltmeter & switch.
Battery: 4500 mah 6s x 4 in 12s 9000 mah format (99whr battery when seperated, air travel safe)
Battery bag: https://www.amazon.com/gp/product/B0725P7BR7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Its cushoned, splash proof, in the winter it keeps battery warm, in the summer you can unzip to get venting.
Pelicase 1150, 12s7p 30q from @pjotr47
Unity in 3dservivas case
I use a single set of battery for multiple boards. keeps my wallet happy
Bag: https://www.amazon.com/gp/product/B0721Q7PGM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Dual compartment. Vescs and electronics on the bottom, battery on top. padded, splash proof, insulated for cold zippers for vent :slight_smile:
Two Turnigy 12Ah 6S Lipos in series.
Case:
AmazonBasics Hard Camera Case -… https://www.amazon.com/dp/B01L0LVDJO?ref=ppx_pop_mob_ap_share
Fits up to dual 22ah hrb 6s (I.e. trampa monster box equivalent)
Update: fits 14ah 6s tattu lipos x4
@Riako :pray:
@glyphiks :pray:
@seaborder :pray:
Ok here we go
Pelicase 1150 bolted to the deck with rubber rings between bolts and deck.
M4 countersink bolts and 2mm thick square nuts with Loctite, never came loose.
What’s inside right now, a self-made 12s6p of VTC6
Then a sturdy divider to seperate the battery from the BMS inside the enclosure. I bent 0.8mm aluminium sheet to desired shape.
Cushioning everywhere, mostly a combination of hard and soft foams.
For the vescs I bent 2mm ABS sheet with the heat gun.
4 x HRB Lipo 6000mAh (12s2p)
Hook & loop heavy duty
Hook & loop straps
3D printed protectors for BMS connectors
BMS connectors with hook & loop attached to the battery for safety
Loop Key with anti spark XT-90
