It would be pretty heavy and overkill If you’re doing that…You’d want like a 12s8p, 12s12p battery with an insane BMS. Although, there might actually be room in the 40" Drop Deck for a 4WD.
For commuting a 2wd with 12s4p is more than enough typically.
One of those is more than enough on my commuters. Four of them is just ridiculous.
One 6380 is fine, two 6355s are fine, two 6374 are overkill. Four of anything but 5055 is overkill for a commuter board, and even that is overkill because of the extra electronics, mounts, gears, et cetera.
2 6374s are not overkill for riding 30+mph on a 12s build where the excess heat becomes apparent with smaller motors (I live in hawaii so it is hot all the time)
