Subject: [Dallas, Tx] Item 1 WCS 4WD Killshot which has been improved by Damon at LHB Description: (UPDATE SOLD)Looking to sell complete, or parting off depending on what comes first.
This is a 4wd with four 6374 maytech 190 kv motors and four 100A maytech vesc that are synced in a ppm configuration. One of the maytech motors has a snapped motor pulley stem, but the motor is still functional.
The battery is a 12s5p with 40T cells that’s been improved and made safe by LHB. Enclosure is cracked.
The deck is a 38 inch killshot deck with front and rear riptide foot stops.
The trucks are chamber trucks with riptide bushings for someone under 190 lbs with tall barrels and tall cones. Also comes with motor mounts on each truck.
Comes with four 6x2 six shooter wheels and wheel pulley on each. The outer flanges are chipped but functioning.
Comes with a 2A and 6A charger
Runs with a hoyt puck
Bought it for $3,300, but got $75 refunded since I requested a 12s6p battery, and they builder tried to sneak the 12s5p. So really paid $3,225 for it. Taking a hit for this one.
Hey everybody, I will rebuild WCS batteries and put fishpaper between the pgroups and check the welds and replace rusty fasteners with stainless ones and put 15 mm pulleys on those 15mm belts instead of the 12mm pulleys with the flanges knocked off that they often ship with that don’t quite fit the 15mm belts on them and put real bolts and washers on the enclosure instead of countersink magnets which aren’t actually washers and even load a 280 amp eswitch in there and get rid of the second switch which is designed to keep the first switch locked but somehow jumps all the internal eswitches together that exist inside the 100 amp v4 based maytech ESCs that i now have a drawer full of because i have to replace at least one of them every time i see one of his builds …
oh and wrap the phase leads in sleeves because… you know… they’re being tunneled through an aluminum truck and not something non-conductive like… i don’t know… a riptide riser…
and replace the plastic truck plates with metal ones…
Also @longhairedboy you’ll actually send the requested battery! Instead of trying to sneak in a 12sp5 battery when a 12s6p battery was requested and charged!
