Hi!
While opening my new makerX Go-FOC HI100, because of another reason, I discovered to pins labeled “RX” and “TX” on the Pcb with “UART 2” written above it. Does this mean that I can solder a Bluetooth module on these pins and connect for example a VX2 pro remote to the COMM UART port and both will be able to work simultaneously without any further modification?
YES,they work,on VESC TOOL needs Enable the permanent UART (default Enable)
Thank you!
But second UART port is so useful, so why do you hide it in the enclosure?
