This version will increase side wire clearance, increase our lot size so we can reduce the price and makes the part more versatile in that you can choose to buy one of each or two of either one for each truck depending on what you need to do wire wise. Please let us know your thoughts.
This looks great Brad! The thinner parts (bottom) also look thinner compared to the previous design, is this correct? Also, any reason to believe this 2-piece design would affect stability in a any sense compared to the old design?
@amanuelamanuel when you say thinner, do you mean the connecting web between the mount hole standoff positions? I do not believe the two part version will effect the stability of the riser at all. It will be tested to be sure though.
Yes, that connecting web was what I was refering to! I found that mine was a bit tight if I wanted to route the sensor wires through there as well. It all fits, just a wee bit tight. If that web is thinner it might allow for a bit more wiggle room and ease my insecurites of hurting any of the wires
Do you mean are they rigid? The current tunnel trucks offered on the website are made from 60D urethane, conform to fit the concave of your board, and are supplied with hardware.
