I have run motor detection fine through the Unity app. I’m trying to connect the vx2 but it won’t calibrate. Has anyone got any tips on how I can get this working?
The VX2 is a UART only remote. UART does not require a setup. The setup is for PPM remotes etc.
You can calibrate it via the remote settings itself but i think it’s not a must.
I’m plugged in through the UART and the remote is on but it won’t budge the motors.
Probably 115200
It’s working now! Bit random but thanks for the help!
Hi, so i have put in uart, calibrate with the remote and nothing. If I press the throttle nothing on the screen and the motors are not moving. What can I do? Return the remote? 115200 baudrate too. If I try using my hoyst remote everything works. Grrr.
I have also broke the 7 pin connector. So, I’ve put another one with the same 5v, grd, tx,rx connected.
