Hello, I am looking forward to building my next board. I am more or less decided on all the parts I want to use, so far it is:
2x Torque boards 6355 motor
Loaded vanguard deck
Caliber II trucks
Orangatang caguama wheels
drive train and controller will be DIY to add my own touch
Battery will be also DIY 12s1p from turnigy 5000mAh cells
The only thing I am not decided on is the ESC.
I was considering Flipsky at first, but I am worried about the quallity.
Also when I was browsing diyelectricboards site I saw that they are preparing VESC 6 based ESC. So maybe it is wort to wait for.
Or are there better and affordable options for the ESC?
I would like to hear your opinions on my choices and maybe you could help me decide my dilemma with the ESC.
Only other concern is 2 X 6355 is a tight fit with cal2 trucks with 15mm wide belts also most pressfit pulleys won’t work with them without modification. a lot of bolt on pulleys also require some filing down of the hangers. Torqueboard or Paris profile trucks are more pulley friendly.
It also requires two ESCs, but you can use ESCs rated for much less current.
But if you have space and whatnot, dual small motors is better than single huge motor. It’s more expensive and physically larger though and often heavier
If I used motor mounts on a round hanger, I would JB Weld them as soon as I knew they were in the right place and the belts ran true and I rode them 500 meters to verify
Fortunatly I have access to the spot welder and soldering station, so I think I am covered there
What other expences besides BMS can you see in batterymaking?
