Radium Mach One S - Unboxing
https://youtu.be/qBhWiCHMKA0?is=tgvEJGrZR6xCI7um
Hey mate, good unboxing.
However I noticed you removed the nylon locking rod from one of the rear wheel nuts, as well as not doing up the wheel nuts fully tight.
With no nylon lock and no Loctite, there is a risk of your wheel falling off. If you’ve already discarded the nylon piece, please contact us.
I watched the video and it’s really tempting. If I weren’t in Brazil, I would have already bought one. Here in Brazil, if I were to buy a complete Mach (since it’s outside the United States), I would pay around $6,000 for it with shipping and Brazilian taxes, which are 77%.
Ouch.
You’ll just have to mine resources, build a factory, and produce your own electric skateboard I guess.
Thanks amém ![]()
At the time, I thought it was just a plastic piece! The wheel locks have stayed secured like a standard nut, 200+ miles in, but I’ll check this one in particular and apply Loctite if necessary.
As far as tightening the locks, I was under the impression they should sit flush against the bearing, but I didn’t want to overtighten them. I’ll reassess that as well.
Thanks!
