Ok so I just received my bergmeister wheels today and on the tire it says 60psi max, however on the website it says 85psi max. What pressure are you guys who have these running them at?! Screen shot of tire description below:
Screenshot_20190823-162002_Chrome|281x500
I usually run 60 psi, any more than that and it seems a bit too hard for me
I run mine at 50ish psi but i usually ride asphalt. If you’re trying to offroad on dirt, id go 35-40
Ok thanks for the feedback
@165lbs 40psi for me
Bear in mind that when you disconnect the air hose you lose about 5 -10 psi so crank it over to compensate. I pump mine to 70 and pull out hard.
credit to @Brenternet Which is something I never thought I would say…
I always pull out hard.
Pull out king
I highly recommend a shock pump. Their have separate knobs to thread on and open the valve, preventing loss of pressure. They are designed for low volume, high pressure (up to 300 PSI) but work great for small tires such as these.
I also weigh 165 pounds and ride 50 PSI on streets.
I always run them 29psi (let say 30max
like for all my esk8/eMTBoard air tires for yrs), I’m 75kg …
