i routinely fly my board between home and school with a currently 18s2p-soon-to-be-basically an 18s4p, all split into 6s1p packs
i think 13 sets of 4p isn’t a bad ideaaaaaaaaaaa, TSA doesn’t care how many packs you carry with you long as they’re all under 100Wh, be ready to be routinely stopped at security for them to swap the packs
I havent done much but design the brackets I’m going to use to prevent wheel bite. These are angled because of the Adjustable baseplates im going to use and I want this to be a low rider with adjustable ride height
This is two parts that will bolt together with the mounting hardware. It will attach to the deck from the top and bottom. When the two peices come together they end up being a quarter inch of stainless steel. More than strong enough for my weight.
Ah fuck how the hell am I going to get this to be modular. It’s gonna take a miracle. What do you think will happen if I charge this at 10a while the bms is rated for 8a charge?
Well of course I’m going to fuse the charge port. But what methods should I used to connect these packs together in series? I’m thinking a bunch of bullet connectors.
Bullet connectors should work, its going to be such a pita lol, especially with balance wires too, GL. As far as charging…I would never charge a 4p pack at 6 amps, let alone 10 on a bms thats rated for 8 maybe buy a new charger?
Lol I’m that friend who is looking for something like that. Just not sure if I should go with something like gbomb or like yours. Going for pure aesthetics but quality performance
