Im definitely going to sort that out. Do you think the motor will still be ok?
Great. I might go for it. Iāll have to have a thinkā¦
consider switching to mr60 connector
https://www.amazon.com/dp/B07X223LK3/ref=cm_sw_r_em_apa_i_BxpKEbX07HGH3
That could be but I definitely would check resistance between the phases and phases to ground before to be sure the windings didnāt short out somewhere else as well.
Phase to phase should be close to 0.XY ohm. A to B, A to C and B to C need to have the same value.
Phases to ground should be open end.
I was having an even closer look. And the blue capacitors are different than the ones on the flipsky website.
I didnāt even notice that, Iām not sure if itās a different batch or a different product. You are probably safer just getting it from the Flipsky website or buying a different VESC.
