Pair of HALL sensors is dead in one wheel?
Makes stuttering noises too
Welcome to the club! What motor? How old? Ride it hard? Get hot?
Very sorry
Craptor 2.1! Ride it hard… ehm not really. Doesn’t get too hot I believe. Wheels are cracking if course. Roads in Belgium are quite rough though. Got it in september. Wish I could see total driven distance somewhere
ride it sensorless - those hall sensors fail as regular as the sun comes up
What? Really!?
What’s the downside of that? And should I just disconnect the cable then?
A small push or hip movement is needed to get the motor spin a bit before it can take off, otherwise no real loss also very slow movements may be a bit choppy.
:smirk:
Ride sensorless, use BLDC and do the parameters for that. It should not be a problem. You can play with the throttle mapping and the positive/negative ramping, to get more punch and less rattling…
Would you just unplug that black screw on plug to disconnect the sensor? Also, is this an app for androids?
