Cool to know that, hope mine stays this time :+1
Thanks for the tips!
What kind of charging jack/connector does a boosted board/charger use?
You donāt really look at NM in esk8. You see If you have big motors like i stated above and you you have a battery powerful enough and an esc that can handle great amps, then you will have plenty of torque.
You canāt have to much torque, the more is better. It can always be reduced via software.
I might create a thread about it because a lot of people ask about it and it is spoken little of on either forum.
Hi guys,
one or more of my Mytech 6355 hall sensors is toasted.
Got a spare pcb and sensors, what I need is an advice about the epoxy to be used to glue the pcb on the windings. Any advice?
while setting up a battery indicator do i select 10f or 10c
I have a 10s2p battery
I thought L and P were the options, L for lithium and P for lead. I donāt know what f and c stand for. ? F might be LiFePO4 or ferrous
Whichever one says 100% at 42V and 0% around 34V
Gonna ask again,
Does anyone sell 80mm motor mounts, or does anyone have an stl/cad file for one?
I think E-toxx is the only vendor Iāve seen that deals with 80x stuff, and I believe itās an chain/gear drive.
There may be other stuff out there but itās not super common outside of eMTB from what Iāve seen.
I am aware I just had this stuff on hand
You got a link to what you would use tho?
another quick question, while trying to align my drivetrain, the motor pulley is bound to touch my 107mm wheelsā¦
-or i can let the motor pulley cut into the wheel
how do you guys handle this usually ?
On what mounts? Assuming your belt length wonāt let you move pulley forward, longer belt and then repositioning motor pulley. Adjusting distance better than messing with pulley alignment to get clearance.
its the e -caliber trucks and mounts, the problem emerged when i switched the motor pulley from 15 to 18t, it seems you are right, since they are adjustable a tiny bit further out i probably need longer belts
Will be setting up my board soon and was wondering if I could get help on what settings would be best to use (vesc tool) for 12s4p 30q / 2x 190kv 6374 motors / Flipsky dual 6.6 plus.
If you could answer or shoot me in the right direction that would be much appreciated
I have this battery meter. When I turn on my board it shows voltage counting up and then it shows 0% and the backlight turns off and the battery icon flashes. Its set to the battery I have. Any ideas?
Some battery meters have settings for that where you can set how long it displays, swap between Voltage and Percent for example. Mine shows a battery Icon with different parts filled depending on what setting i choose.
I took a quick video of what happens. https://ufile.io/h73f4x72 That might make my issue a little more clear. I double checked and the tester is set to the correct battery type
That looks broken or something. I would contact the seller
I use
60 Amps Motor
35Amps battery (10s4p 30q
Max Motor Regen -7
Motor Max Brake -60
Dual 4.12
Dual 6374
