Iāve also made it home on a single wheel drive with one phase wire disconnected. (melted apart inside enclosure) You couldnāt go slow and had to have the throttle mashed to have any sort of power. Brakes sucked but didnāt suck as much as the throttle.
Yeah, I was also super-confused until I cracked the enclosure open and saw which wire was melted apart, everything I experienced on the streets made perfect sense then. At first I didnāt even realize I was going to be able to make it home under power. I had to kickpush really fast before I had throttle ability, and I had to pull the throttle really far in.
I really donāt know how much offroading you want to do but @tazās evo board should be good for shitty roads. A Hummie deck is quite versatile and has good enclosure options.
I just fell in love with @Venom121212 Circuit Board omg. Does @hummieee have a website or do i have to DM to see all his different boards.
and @moon DM me so i can get a quote on your Drives.
Mine got disconnected while I was riding (I guess) and 1 of the motor hit full brakes and threw me off the boardā¦
Ate the ground but luckily I was slow and also had full gear onā¦
The odd thing is that I didnāt know it was disconnected at that time and it was riding just fine after my fallā¦I only noticed that 1 of the phase wire came loose after I examined the board thoroughly after the ride
Hey guys, want to charge my board at 4 amps and busted a fuse. Went to autozone and bought 7.5a fuses, will they work correctly? Connection is between negative charge and bms
You want the current rating double to triple what youāll use it for. Voltage rating ideally should be 58V but if itās 24V itās not the end of the world and itāll work fine
