Thatās assuming 90mm wheels?
10S on 15/40 with 107mm or 110mm wheels moves my fat 210 lb ass around town just fine. With one motor.
I will reupload later when I get home. I think Iām just gonna load everything up in my Google drive.
Do you have the link on how to quickly check the motors by shorting the phase wires? I cant seem to locate it from here or on builders.
My ninja search skillz arenāt working. Thanks
But thatās only a measly 23 mph top speedā¦whereās the fun in that?
Anyone remember who had the mountainboard question where one side would randomly spin backwards? It was in the last few days I think
Mine go a lot faster than 23mph (37km/h), and thatās on 170Kv
24 at full battery I guess
More like 26.6mph (42.8km/h) loaded and 29.6mph (47.6km/h) on the bench
If you click on the calulator at the top, itās actually the default setting
170Kv 10S, 110mm 15/40
Wait I had the AT efficiency plugged in, Iām dumb and blind
Can you expand on that? Are you saying that adjusting the battery regen voltage will affect braking at high speed more than at low speed? I havenāt got that straight in my head yet. Which charging and amperage limits translate to the mechanical āam I going to face plantā part of braking.
Adjusting the ābattery minā voltage current will affect braking at high speed more than at low speed. Adjusting the āmotor minā current will affect low-speed braking more than high speed.
Thanks for the clear answer and the correction on voltage. I got it right once and wrong once. Iām a mechanical guy at heart. I tell people after 25 years of working with antennas I have learned how to spell RF.
On Mouser I see that XLR connectors only support up to 50v, would that make them a poor candidate for charging my 12s7p 30q board? What do you guys use for charging 12s boards?
@Sn4Pz
You could go xlr if you take the right one.
http://www.switchcraft.com/Documents/switchcraft_sealed_xlr_npb_604.pdf
It has a vrms of 125
I personally just went xt90 with 10 awg cus I like going overkill
I canāt go xt90 as thatās going to be my loopkey, and barrel connectors wonāt be able to handle 8a+
Not exactly sure how vrms worksā¦ Iāll keep searching
Go xt90 for loopkey and xt60 for charging? They even have a mountable version
12s6p 30q pack. 4a charger in the mail. Might want another one for on the go. What is the biggest i can go in amps to charge it faster without ruining my pack?
Technically you can charge at 2 C, or 24A with that pack, but I wouldnāt go that high unless absolutely necessary. 12A would be okay
