They are, and are likely the 75kv versions that came out right after the original ones like mine. (They made some 58kv with this can style.) The guy with the most information on this is @mishrasubhransu
Are the guys from Metr also on this forum?! I ordered a Metr ā¦ now Iām wondering how long it will take to get this package from Germany to the Netherlands.
i used to be that guy. Donāt follow this topic anymore.
Thank you. Figured Iād get some info on it before gettin rid of them as they are just taking up space.
support@metr.at
I need to order flux right now. Any recommendations? pref amazon. tubes vs tubs vs syringe? types?. Iāve previously only used the flux that was in a desoldering kit I had.
Thanks for your order. Answered your Email.
Thank you Dario ā¦ I read it (all these cryptic names arenāt helpful ) who would guess hexacopter did metr ā¦
Very helpful. I sometimes struggle with trusting my solder work.
Same hereā¦its been working pretty good for me.
Iām still confused about the ESC settings (motor, battery max and mins also brake settings) Could not find a thread that explains each setting in detail. Anybody have a link?
This is from the glossary of terms, does it help?
Would this charger for a 12s 4p 30q battery be just fine? Or is there a different battery charger that I should be looking at? Need HELP
Any 12s charger under 10A is going to do you just fine. Just find the right plug is all.
okay perfect this one has the 2.5mm jack that I need ! So Thank You!
The 5.5mm x 2.1mm jack is more widely used than the 2.5 version.
