Nope, connection seems to be ruled out because the bar is steady when I paired it with another VX1 remote that I haveā¦
Maybe something in the remote itself but I do not know what is causing thisā¦
I want to 3d print sleeves that go completely over my motor (to prevent debris and water from getting in)
Iām concerned about the slots that are in the motors, would this mess up cooling?
I printed myself sleeves a year ago, thats still the first set, no cuts or anything broken. Printed with flexible TPU in the mode āSpiralise outer contourā (Vase mode) The motors definitely see an increase in temps but thats by all means not a huge margin.
Color is black because i only had white at that time.
I usually put them on if i know it gets dirty,muddy,wet or rocky. They just slide on and off.
What tolerance did you use? Iām thinking just making the diameter 51mm for my 50mm motor so it slides on easily
the torqueboard motors (6374) have a outer diameter of roughly 63.80mm The file i have from the sleeve is 64.14mm with a line width of 0.4mm, so technically 16mm per side (but somehow that sounds a bit much).
Canāt say 100% because i used different slicer settings back then.
I printed several prototypes to get the best fit.
Just wired up a new board and the charger is only charging @ 300mA. Iām trying to figure out if itās me or the hardwareā¦ I have a smart bms wired charge-only to a 12S 10AH battery, and Iām charging with a 12S 8A lipo charger (links below). I havenāt used this charger before, and I donāt have a power supply handy. The BMS app doesnāt appear to have any settings concerning charge rateā¦ Could I be missing something obvious?
BMS:
https://www.aliexpress.com/item/32819508078.html?spm=a2g0s.9042311.0.0.27424c4dMmR0ir
Charger:
https://www.aliexpress.com/item/32824519129.html?spm=a2g0s.9042311.0.0.27424c4d6EMf4A
Do I have any options for pneumatics/airless wheels on caliber II trucks? Or do I need to get a new pair of trucks?
I use torqueboards all terrains on my caliber IIs, any non-trampa wheel will fit. bergs, trqbrds, 6shooters.
Thatās a first
Gotta keep it fresh.
Yeah im pretty sure DKP trucks are 8mm so you should be good.
I think they are 10mm, but as long as I use 8mm bearings I should be good right? Also, what kinds of bearings goes into these types of wheels? Just standard ones like zealous?
Never used pneumatics before
Evolve DKPs are 10mm spun down to 8mm at the hub. Itās only 10mm where the pulley sits. You should be fine.
while bergmeisters and evolve wheels all do well on an 8mm axle, Iām concerned that caliber IIās donāt have enough axle length for the hub and pulley. maybe the offset six-shooter hubs would work. I donāt know though I havenāt tried
edit: listen to this guy
You could use bergmeisterās on a standard axle with a bolt on pulley
Someone asked me this does anyone know the answer?
I have dickyho motor mounts, and I wanted to get belt tensioner. The issue is that dickyho is currently down. I have a bunch of extra skateboard bearings. Theyāre pretty simple, so I was wondering what I could get from home Depot to screw the tensioner in place?
