Got this right away in the Ackmania ESC tool.
Using the OG Focboxes
@Scepterr updated the vesc to the latest firmware, is this causing this issue or is there something else ?
Make sure the cable is actually plugged in, focbox have a tricky USB port, and make sure to choose the new port when connecting with the tool
This ^^^it needs to be fully in
How will I know when it’s fully in? Do I have to take off the top case ?
yeah make sure under “connection” you choose the right comm port
Maybe @Scepterr updated them to a firmware higher then your version of Vesc tool supports? Or try closing out of Vesc tool and going back in and trying again.
I’m setting it up on the ackmania tool, will this affect it
I also always use Ackmaniac. Exit the VESC tool program and then go back in and that works for me usually
Still nothing
checked the comm port? Maybe uninstall the port, close the tool, unplug the vesc, plug vesc in, open tool, choose comm port, try connecting.
Operating system?
Windows 10
if you click the arrow left to “Baud” do you have multiple comm ports?
if yes test each one by clicking on it and pressing connect
I had problems on windows 10 but that might have been because my USB drivers were not good. I just used a Mac and Kugs old MacBook Compile of Ackmaniac
You can use a Mac ??
I have a feeling your USB Drivers are not compatible… Do you have access to a MacBook?
Yes I got a brand new one sitting next to me
Yes, check the other forum and look up @Kug3lis Ackmaniac, If you give me a couple minutes I’ll grab a link
