Unphhhh
π NEED a Storm Core Owner and a Unity/Xenith Owner (Preferably people that also have 3d printers)
I did, but Iβll start the new one in a few.
ok. sorry
No worries at all
Ironically, Iβm printing in my only PETG which is Orange as well haha. My TPU I made for a water sealing spacer on the Stormcore enclosure is lime green.
Awesome quality for petg. Which printer did you use?
Any one els zooming in trying to see witch upgrades are on multiple printers
Thatβs just pla but ender 3
sink is printing now
Mine had a weird spot of gaps where 2 holes lined up perpendicular that might just be due to my nozzle size being larger than the wall thickness. Curious if you will have the same result.
Yeah thanks. I checked the wall thickness and it is quite thin. Once itβs tapped, it will be even less.
Is there any room for those 4 tapped holes to be moved in? Seems like with the storm core, there isnβt much space.
I can make the fins portion taller and that will remedy it, but then the space around the fins will be even less. Personally it doesnβt matter, what do you guys think?
Right now there is 3mm along the long edges of the sink
Making it 2mm, would solve the issue, but might make it a bit trickier to mount.
With the unity yes, maybe 2-3 mm
But not with sc at all right?
Do you think a smaller gap between fins and outer edge is fine? That might be the easiest solution π€·π½
I was thinking that as well
