I am converting my daughters board to electric. She loves this deck. Each block in the pic is a 21700 3P group.
The Focbox is just to show scale.
I will make a custom enclosure to max space but as you can see I am very tight on space.
What would be a good BMS and ESC for this? I won’t be drawing a ton of amps, the idea is to give this board a decent range so she can ride as far as Dad
I hope the image works.
Edit: I just realized I’ve been thinking in two dimensions only. The only place the enclosure needs to be thin is through the drop section. I can make a larger compartment close to the truck where clearance isn’t as much of an issue.
