Motor recommendations / What to buy
Sup guys, soooooo for my next build i want some nice 6374/80 motors. But im really unsure on what to buy. I want sensored with temp. Also it needs to be in the 190 - 200kv range, as I’m running a 14t 8mm motor pulley.
Has anyone a recommendation for me? Or has someone the perfect pair of spinny things? I’m located in the EU.
Maytech 6880 are a option have the same mounting pattern as a 6374/80 motor.
But I don’t know were u can find them in EU now days.
Have them and i think he’s in Belgium.
Aliexpress carries the new Flipsky 6374/80 battle hardened design. I have 6374 and 6380. Both 190kv. The 6374 have been great so far, haven’t used the 6380s yet
Why not pickup some 15T or 16T pulleys and run the Flipsky battle-hardened 170kv 6374s? Nexus Boards has them in-stock at the link that @Fosterqc shared above. Ben is a great vendor too BTW.
You will have better tooth engagement (less belt slippage) than you will running a 14T pinion gear and you can achieve similar top speeds:
Well I already ordered some 190kv 6374s directly from flipsky, that’s cheaper than picking up additional pulleys that I already have. But thanks for your recommendations, I need some motors for my other board too. :sweat_smile:
