Yes, that’s right, 110 MICRO amperes
Fuck yeah. Does it have a precharge circuit or is it an inrush-limiting design?
Inrush current limiting by dV/dt control.
nice!
Not sure what DMM you’re using but the accuracy are usually shite on that small values even on the very expensive ones. Do you have a very accurate DC supply to verify current draw? (preferably recently calibrated)
EEVBlog did a review of the multimeter, and the measurements corroborate theoretical calculations.
I.e. quiescent current specifications from datasheets, and a measurement of MCU active time.
I can also verify it by measuring the voltage across a 100 ohm resistor.
What load capacitance would this be good up to?
6,000 uF
