moon
December 8, 2019, 7:42pm
#1
I want to collect data about the tolerance range of this dimension
If anyone has a pair of calipers and some hangers on the bench lmk what dimensions you get. From the end of the m8 brake hole to the start of the 12mm axle.
On my hanger the value is 35mm
Pretty weird request so I don’t expect many responses but even 5 other values will help me out
@MBS
Data
Distance
User
33.85
moon
31.00
excess
35.60
Mainsedora
33.50
RyEnd
35.11
rich
34.49
rich
35.10
rich
38.29
rich
32.67
Tamatoa
37.15
whaddys
35.81
whaddys
33.00
Chricious
35.25
A13XR3
35.44
A13XR3
31.90
Venom121212
31.68
Venom121212
34.00
Not2tall4esk8
34.00
Not2tall4esk9
I really need a set of calipers
35.6 mm
And yes it is a 33 year old caliper.
moon
December 8, 2019, 7:58pm
#6
moon:
Data
Good data already. I think Andy has something near 35mm too
I measured 42.4 mm and then substracted the 6.8mm hole.
moon
December 8, 2019, 8:10pm
#10
For the gear drive yes, Im just planning ahead for what spacers to buy etc.
Im already aware that this range is quite large but it doesn’t make a difference to the drive its important for assembly though.
Hold up, are you guys measuring in a direct straight line between points (diagonal) or lining up along the hanger?
As the crow flies it is. One sec
rich
December 8, 2019, 9:31pm
#14
Measured 2 hangers, here the results
35,11mm
34,49mm
35,10mm
38,29mm
Tamatoa
December 8, 2019, 9:59pm
#15
I have 32.67mm but I only measured one.
rich
December 8, 2019, 10:51pm
#17
I’m just curious, is your drivetrain that thin or do you use truck extensions?. The space on the axle is limited. And if you move the drivetrain more toward the baseplate the motor size is limited.
moon
December 8, 2019, 11:03pm
#18
What can I compare it to?
I suppose your geardrives support long motors becaue of the axle extensions
RyEnd
December 8, 2019, 11:36pm
#19
How much room is there between your drives on the MBS trucks? Width between hubs - (41 + 41)?
