MakerX D75 Power button
I needed to swap out to a larger button for my D75 and found an old Unity/Xenith button with 4 pins… Do the Vbatt and SW pins on the d75 need to be connected in any particular way to the two white mom wires from the unity button? I’ve tried connecting it both ways and they both seem to turn on/off the ESC without any noticeable difference.
Nope! As you discovered in your testing, it doesn’t matter which pin the two white wires go to. The button just shorts those two white wires when pressed, so order doesn’t matter.
Thank you!
