esk8.news esk8 calc donate now
Maker-X DUAL DRIVE VESC.4
Developed based on VESC hardware, the Maker-X Dual Drive V4.
Perfectly compatible with the vesc tool.
Smaller size! Same performance! Lower price!
WWW.EBMAKERS.COM
MAKER X
how to connect sensor wires to it? need to remove the cover? or is it on the bottom?
Looks like you cut through the heatshrink and plug them?
Hall sensor port is here
Can you break these apart into two fully-functional single-motor ESCs?
Or if one fails, replace only that side?
sorry what I meant was how to attach sensor wire with the metal cover?
Which metal cover?
It’s the other side with heat sink.
The side with the plugs is only covered with heat shrink
ah ok I get it now, thought it was like those full cases
Can port is via the pcb or JST?
upper right corner are the connectors can’t answer if they’re internally connected tho :smile:
Oh God why does my title have to be true…want this so bad…kids can survive without food right?
yeah at least a fortnight, you should be fine
Good to know. Should save me about 400$
@YUTW123
This is a need-to-know
Can not be separated, is a whole piece of PCB.
Not without solid reviews from trusted community members, thousands of miles of varied terrain tested on a hundred different motor and settings combinations.
Once you’ve got that sorted I’ll be happy to jump in :+1:
Bought one of these just now, will be posting in my upcoming build thread as soon as a receive it and ill try to do a pretty comprehensive review on it as soon as its in my hands,
@b264 is a big fan of backup plans, redundancy and over all just in case preparation.
His point is (and he asks/demands this for all dual ESCs) that as long as every component is in place 2 times there is no logical reason to replace a full dual unit if one side fails or get damaged. But he also dislikes dual ESC systems with a single MCU for example, as the cost of a second MCU isn’t worth the risk of loosing the controll of both motors in a bad situation.
BTW I personly like the idea to just have one/two PCBs attached by PCB breakpoints and screwed onto one heatsink. If one side fails you can get a new one.
