looking for pics of tb v6 motor mounts in normal orientation
First build so I could very well be messing crap up but I’m looking for pics for torqueboards v6 motor mounts installed in forward orientation I’m having issues with no clearance between gears and mounts
And yes the hanger is clearly bent I’m hoping that’s the clearance issue I have a new hanger from tb on the way and I do have spacers on before I put the wheels on
Is that a evo? @torqueboards can you help this gentleman
Yes already emailed him
This is exactly the reason I got rid of these mounts. Can’t adjust anything which makes zero sense to me. I’d like to know the solution to this too, so I’ll be watching :eyes:
Basically I had to use speed washers on top of the spacer and that gave me the clearance if you have the 12mm belts it might not be needed I have the 15mm belts and it rubbed just a tiny bit
Before the washers
