For the E-TOXX psychoframe, I bought 5x TATTU Lipo 4S 22000mAh 30C.
One of them takes a while to balance.
I first balanced/stored with Turnigy QuadKore to 3.85V. I was quite long.
Then, after some tests of the psychoframe, I noticed cell voltages were a bit different (but above 3.80V).
So I balanced/stored with SkyRC D100 to 3.80V, thinking it might be a better balance charger. Quite long again.
Yesterday I balanced/stored again with Turnigy QuadKore to 3.85V and it took 174 min to charge from 3.80V to 3.85V, most of the time at 0.3A (charging current was set to 20A).
Resistances on all the cells are very good, from 2 to 3 mOhms, as reported with these two chargers.
I never experienced this kind of issue in the past with lipos that have normal cell resistances.
Yeah, but what surprised me is that balancing the whole pack from 3.80V (store voltage of SkyRC charger) to 3.85V (store voltage of Turnigy charger) took 174 min, in spite of the fact this pack was balanced to 3.80V two days before.
I would not have been suprised if I was balancing this lipo for the first time.
That is weird, my ultrapower charger charges up at max amps till it’s 0.2-03v away from balancing then rapidly drops to 0.2a, that’s at full charge but on discharge alone I know it takes forever, a balanced pack suggests your chargers not charging each cell in sync or the pack is not charging up the way it should.
Was there any voltage drop from the pack in those 2 days?
Not sure at what voltage the charger starts to balance but I think 3.8 is a pretty common default. looks like the 3d cell is the one beeing bled since its highest, you could try discharge it manually with a bidirectional voltage supplyor an e-load. Even a resistor would work(you need a power resistor with bit bgger wattage) 20 Ohm would yield roughly 200ma (around 1W)
Such a fancy charger should be configurable tho? Try change when to start balancing and it should attempt charging to w/e level you set
Yeah of course, what concerns me is the weird behaviour in balancing of this lonely pack compared to the four other ones. I’m afraid it’s faulty. I wonder if resistance measurement is good for such big capacity lipos (22000 mAh).
I sent a mail to GenAce. I have not even charged to 4.2V yet, but I bought these packs in July. Maybe a bit late for RMA.
For what you are saying, I mean charging or discharching a cell the fast way, I found this nice video :
Thanks! This is a very huge build, I question myself about police reaction if I see them going out…
