i was looking at doing a 4wd with some 8074 motors but having issues finding motor mounts to fit these beefy bois. anyone know where i can get some mounts made for these motors or know of any similar motors 63100 rated for 15s?
I had a look at flipsky, alien and TB and they are only rated for 14s. i was hoping to find some moters i could push to their limits. plan on using these with a 15s pack of 21700 cells. i was origionally going for custom moon drives but i dont want to cut the shafts so belts for this board is what im looking at doing.
No worries running them at higher voltage, specially just 1S more
You need to be careful when you you get a high Kv motor and put in a high voltage, then it may end up bad, for example, a 220 Kv running at 18S and with a gearing that the motor reaches the full speed in you regular use
If i was using motors that big i’d much prefer shorter 80mm motors than longer 63s. You gonna want some beefy mounts to hold that much weight tho… maybe @Tony_Stark from Radium can help.
You could play with gear rations the 4WD, for most riding styles, when going to 4WD, lowering your ratio by quite a bit will help if be more efficient, at higher rpms it takes quite a bit of power to just spin the motors, so you make then turn slower since you have plenty of torque
