Sound design is so important in influencing the feel of a product or machine. It also might indicate whether a pulley is misaligned or if a motor needs some lube.
My second build was a single unbranded 5065 270kv with vesc/BLDC and it screamed like a boosted board:
But my third and fourth is a single TB 6355 190kv with focbox/BLDC and it sounds a lot less attractive:
Anyone know what makes a board sound like the 5065? I miss the sound.
Idk I kinda like the way second one sounds better. I have no clue what determines how it sounds tho maybe someone with a lot of experience with lots of different motors (and ESCs maybe affect the sound?) could chime in
I’m going to take an educated guess here and say that open motors will be louder than their sealed counterparts. I use sk3’s and they scream like banshees all through the curve. Much louder than the sk8 or torqueboards which are sealed cans. Also higher kv will produce a different noise to lower. You’re already on the loud setting with bldc so it just comes down to the kv and motor type.
I actually usually always run FOC on my newer builds with the focbox, I was just trying BLDC to see how much louder it is. With a belt drive you really can’t tell the difference
I’m kind of an old fashioned guy where bldc is concerned. I like it loud and raw. Just what I’m used to. Don’t quote me but I’m sure you can change the mhz setting on foc to make it almost silent even with belts. I like people to know I’m around though. I think the difference you are hearing and missing is just down to high kv. High kv motors do sing a different tune.
