The extenders with grubs fitted
@Riako: "Did you got an extended version of the extender !??
Those 230 x 65 look sick !!"
Would you believe they still have mold lines on them! but probably old and gone off. Still light so will give them a go.
T2’s are a bit heavier for sure, maybe a third more but also really chunky. 5* share the same bolt pattern as the Rockstar’s so direct fit the the drive
Tires have N.H.S on them so maybe off a hospital trolley
@Riako: Nice, thanks for the feedback
> 5 share the same bolt pattern as the Rockstar’s so direct fit the the drive*
Yes, Rockstar, R2, R Pro and Fivestar have the same pattern but not the same deepness?
Jens make the test with my Matrix 2 new hanger length last summer because I ask him if I could set 9" wit 5, and it was not possible, maybe the extenders are longer now …*
Its why I was curious, because it’s the setup I want
If I make this layout like I already did, the extender didn’t go out of the 5 rim, as they are wider than the Rockstar2 …*
(As my board didn’t roll anymore, I will unset and measure them. But the 5 wide is around 39/40mm, Rockstar is less, around 37.5mm if I remember. And Trampa are 35mm deep, they will need washer…) I will make it just like you ^^ (with T2, after finishing my Primo Stricker I guess)*
Witch motors will you choose?"
To be honest I don’t know if the rear extenders with the drives should be as far out as they are, maybe because it’s not fully threaded to the axle.
I think I should examine more before loctiting, this is a mock-up
Mr. @Nowind probably knows the answer
