Here it is, the one that started it all.
I embarked on my DIY journey on February 2018, and little did i know it would grow… like REALLY GROW.
Do note that this build started off weirdly, using odd configurations, but later was changed as i expanded my knowledge on esk8.
Ok here goes. I had a Earthwing Chaser 32", with Caliber IIs and Kegels, hoping to turn it to a dual drive.
Electronics wise, i went with these.
Torqueboards 190kv dual 6355
Torqueboards VESC, 2x
Torqueboards Motor mounts, 2x
Torqueboards Motor and wheel pulleys, 16/36T
Lunacycle Antispark switch
6s4p 30Q LOL
And it came in a week after ordering, fast!
Also, using Psychotiller’s Coupe enclosure
Getting there, and starting to drill for inserts and all.
And the first test ride was awesome! Then the motor mount came loose. I’d say its user error because i didn’t know how to mount them properly. i did use loctite. But i secured the set screws in a way where all four of them was suspending the truck hangar, so the mount did not touch the hangar, just the screws.Also, i found that this deck flexes a bit too much for comfort when on the kicktail, so i ended up changing the deck to a Kebbek Rockin Rookie 38", a pure downhill deck.
The birth of the Kush
Also got @Janux-esk8 Caliber II mounts at the time.
Painted it hammer black Turned some ‘anti slop’ plugs. Does make it more responsive!And its done! This is logged at April 2018.
Fast forward to July 2018 and the top speed of 25km/h from a 6s battery on 80mm kegels was killing me as my skill level got better. I got my hands on some 100mm Boas.
Also got 44T @BuildKitBoards pulleys for the Boas.
Started to build a new enclosure to fit a 10s4p.
Made a wooden mold first.
Fiberglass time!
Also upgraded the drive system to Janux’s new drive with cross bars, able to fit 15mm belts as well.
10s4p battery done,
And got two Focboxes, to run FOCAnd it’s done! Upgraded to 10s4p with focboxes, 14/44 gearing and 100mm softer wheels.
Logged at September 2018
March 2019
WTH ANOTHER CHANGE?
Deck swapped due to the 38" being too long for my taste. This is a Prism Origin V1, 34"
And painted it metallic candy green.
Tunnel risers as well, to make things cleaner.And its done! Hopefully for good…
And that’s about it! Total, this gives me a top speed of about 45km/h, and a range of 40km with my riding style. As you can see, the first build is the one that spends the most in terms of monetary, as well as effort. As i progressed on from the start to finish, almost everything was swapped to fit the ‘skill level’ at the time. If you ask me, i think only the Caliber IIs, motors the battery pack is what remained whereas everything else is upgraded.
Take a look at the progression of the versions, if you would.
Now, one final thing i would like to change in the current version, is to swap to the Hammock Baseplates by @rey8801. This board uses way too thick of risers, and having an adjustable baseplate will increase the ride height, which i am fine with, and also change the angles to suit my riding.
That’s all folks! Uploading the rest of my build threads soon.
