nice hub motors!
Just in case you’re serious: There are no hub motors (yet)
Now there are:
and they’re beautiful Had to buy another truck since the Caguamas on 8.75 inch are as wide as the Neohubs on 8 inch.
Since it will be a trick-able board Its a bit different from a regular eboard. It needs something to control rotation direction of the motor when turning the board 180° since you always want to go into the direction you were going when pushing the throttle I have a gyroscope module I could use but it might be easier to just take the measurements from the ESC.
I also marked the unloaded center of gravity and will try to achieve balance by using the cells position.
For now I’ll cancel this project. I figured it makes more sense to just use it as an analog board. For now I’m putting everything into the MOV-E prototype I got from @Luke.
Can’t wait for this one, I’m sure it’s gonna look gorgeous
