iCharger 308 Duo
Description: https://www.icharger.co.nz/icharger-308-duo
Price (AUD): $364 + postage (20% under new price)
The baby brother of the innovative 4010DUO 2000w charger, iCharger’s new 308DUO bring to the table a midrange double output charging solution for the serious RC enthusiast. The iCharger 308DUO offers two 30amp outputs or combine both for a maximum 50amp output power. Allowing for many charge and discharge configurations. Parallel charge multiple lipo packs on one port while diagnosing/discharging another completely different battery on the other channel (some conditions apply).
iCharger 308DUO ads a 1amp 5v USB port for charging portable electronic devices such as mobile phones and MP3 players. Effectively creating a third charging port.
Specifications:
Input Voltage: 10-30 Volts
Max Input Current: <60 Amp
DC Charge Current Range: 50A@Syn. Mode - 30A@Asyn. Mode
Maximum Charge Power Capacity: 1300W (Channel 800W @input > 23.5V)
Maximum Discharge Power Capacity: 80W (Channel 120W)
Maximum Regenerative Discharge Capacity: 1300W (Channel 800W)
Current Drain for Balancing: 2.4A@Syn. Mode 1.2A@Asyn. Mode
Balance Accuracy: <10mv
Lithium (LiPo/Lilo/Life) battery Cell Count: 1-8 series (Per Channel)
NiMh/NiCd Battery Cell Count: 1-20 Series (Per Channel)
Pb (Lead Acid) Cell Count: 1-15 series 2-30v (Per Channel)
Battery Setup Memories: 64
Intelligent Temperature Control: Yes
PC Connect: USB Port
Weight: 0.91 Kg
Dimensions (LxWxD): 171x118x59
Picture of open box showing new item in manufacturer packaging.
