Efficiency - how much power the board is outputting vs how much the dyno is receiving
Top Speed - how fast a board can go, both with no load and simulated load
Torque/Acceleration - how fast to get to top speed with load and simulated load
Braking Power - how efficient the brakes are or how much braking can you apply before lockup
Regen Efficiency - how efficient the regen is
Range - see the distance a battery can last
How are you planning to get the data from the rig? Are you using the motors and esc’s as sensors? If so, you’ll need to account for efficiency losses in the motors and esc’s on the rig…
One thing that might be interesting would be to hook up the rollers to a flywheel with a known moment of inertia and plot the rotation speed of the flywheel over time… That’d let you accurately measure the output power of the board.
I’ll connect one of the VESCs to the VESCTool and get some telemetry from there.
Actually i’m not too sure, i’ll fit the roller pulley on tomorrow, and will be able to do a quick test on a board. And by quick test, i mean engaging brakes on the rollers and have gun the throttle on the board to see which survives
LOL it probably wouldn’t be less than a $100 for me. Nobody around here sells extrusions like that, or custom machined end plates, or rollers… i’d have to order everything off the internet anyway.
I’m definitely building one though once the data collection is figured out. We were talking about converting an old treadmill but this is a way better idea.
I dug up some pdf files from some time ago related to testing rigs for cars, its in German but I guess that you could use deepl or google translate if you find it usefull
Here i am testing a secret board that i can’t reveal much yet.
The rig works well! I have the rig’s remote on one hand, engaging the brakes lightly, and accelerating the board with the remote on my other hand.
Now it’s math time… how do i start
@DerelictRobot! Is there a right way to go about doing this?
